1 - 4 of 4 Posts
Hi
I saw a set of HD vented lowers off a 2012 Ultra for sale. And was wondering if these will fit my 2015 Special?
Hi
Yes, you may have to make some adjustments on the pieces that cover the crash bar going toward the center. A simple cut off wheel does a good job.
Should bolt right on...
Reactions: dbell66253
You shouldn't have to make the adjustments, (cutting) on the 12, they started making the lip shorter and it doesn't interfere with the fairing mounting support, the lowers should go on with no problems.
1 - 4 of 4 Posts
