And having reviewed the results, I'm curious as to what you did with them. You didn't mention what the year, size, or mods of the engine is. I've been reading the manual on my TTS, and I'm getting cross-eyed trying to figure this stuff out. Sure have been a lot changes to that "brain box" over the last couple years. And when they start talking "Lamba," I go into brain-melt-down.
Unless you are an engineer don't worry about the "how it works" stuff like lamba.
Having said that you do have to start with a program that is fairly close, the VE tuning rides are just gathering data to tune the fuel schedule. Just follow the directions, the program blends all those results together itself and writes a new map all on it's own.
looks like you're off to a GREAT start!
just need to try and get more readings in the lower and higher MAP ranges... the lower ones are harder because you have to really try and load down the bike.. try going up a steep hill at lower RPM ranges a few times...:D
