Appreciated and taken as intended!Was more of a dig at myself as I know (2) things about Motorcycle Maint......Drop Off & Pick Up
Thanks again. I have been looking at that indeed. My favourite road is the 99 miles (literally) of twisting highway through Highway 12 in Idaho. Thanks for recommendation. Unfortunately, I have an 8 to 11 hour drive before I hit the first corner whenever I leave home, hence booking it through Montana AFAP!If you ride twisting roads aggressively, I would highly recommend that you look at adding a True Track system to stiffen up the rear end to prevent the 'bagger wobble'. I replaced my swing arm bearings, bushings, and added StaBo bushings, but still had the wobble; whereas the True Track stiffened everything up perfectly.
I have 107K on my 2012, but that is not all on the original engine. It's been replaced twice because of failures in the Cam Chest.2) Local dealership engine guy most work the TBA counter for his day job. Harley tappets are crap. They need to hit the trash bin asap. Did I mention that the tappets Harley uses and sells are crap? Past that the tappets are hard steel, the hole they live in are soft aluminum. The holes wear out before the tappet bodies do.
Harley tappets at 1000 mile service:
First issue was at 59K with a failed Cam Chain tensioner. (Gears are Better)
Second issue was a Lifter at approximately 78K. (Get rid of the HD Lifters)
This lifter had less than 20K on it.
Thankfully, both of these incidents were covered under warranty. However, that meant I was limited in what I could replace at the time, even with additional charges.
I plan to go full gear drive, high volume oil pump, and S&S lifters.
Ouch! I looked at the gear drive, high volume oil pump, etc. and decided to pass on this build. Definitely changing out to aftermarket tappets and Cam Chain tensioners. Any thoughts on just replacing the tensioner pads or the whole units?I have 107K on my 2012, but that is not all on the original engine. It's been replaced twice because of failures in the Cam Chest.
Would you recommend the tensioner pad only (for 30USD$ a set) or the entire mechanism? Seems to me the spring is inside the tensioner pad so that is all that would need replacing? As you mentioned, Drag sells just the pads. I don't want to cheap out on a small component but wondering why I would change the 'holders' out on the stock cam plate.For tappets, look at:
V2313SE HyLift Johnson
Product: HyLift Lifter - Johnson HyLift Lifters
The oem tensions will work fine with those cams. If yours are worn out, Drag sells those too.
I would be good with just replacing the shoes asms. So long as the bores in the housings look good. Being able to buy shoes for the new style tensioners is a fairly new thing.Would you recommend the tensioner pad only (for 30USD$ a set) or the entire mechanism? Seems to me the spring is inside the tensioner pad so that is all that would need replacing? As you mentioned, Drag sells just the pads. I don't want to cheap out on a small component but wondering why I would change the 'holders' out on the stock cam plate.
Yep, I've seen that a few times. And pulled a few tappets where the sides had split but not broken off yet.I have 107K on my 2012, but that is not all on the original engine. It's been replaced twice because of failures in the Cam Chest.
I have the same cams/gears and was going to also post a pic, but you posted my pic. lol. I went with the EZ start cams and turned off my ACRs as well. The Quickie push rods are worth their money, to say the least.Yep, I've seen that a few times. And pulled a few tappets where the sides had split but not broken off yet.
I went with a gear drive on my 110 build. S&S gears, 585 cams, and plate w/pimp, with a 4 degree key from Bob Woods.
Adjustable push rods are a time saver on some engine/chassis combos. But you are better off with non adjustable rods, better yet, tapered non adjustable rods. Stronger, lighter, and you eliminate four points of failure.I have the same cams/gears and was going to also post a pic, but you posted my pic. lol. I went with the EZ start cams and turned off my ACRs as well. The Quickie push rods are worth their money, to say the least.
That would make sense...but I would have to pull the head off then, correct? I might try that someday... retiring next year....Adjustable push rods are a time saver on some engine/chassis combos. But you are better off with non adjustable rods, better yet, tapered non adjustable rods. Stronger, lighter, and you eliminate four points of failure.
What you do with cam timing kind of depends on the what cams you run and what's in the rest of the motor. As well as what you intend to do with the motor.Mentioned cam advance key by Woods. what about advanced crank gear whether gear ir chain drive
Sent from my SM-G960U using Tapatalk
Funny...my 09 uses Blinker Powder also but the manual say to mix it with dehydrated waterBlinker Fluid, WoW my 09 has Blinker Powder!!!
