***************SOLD**************
This has been installed on the bike for 4 months. Originally installed with Rockford Fosgate Spkrs. I didn't like the speakers so replaced them with Hawg-Wireds ZX654 Spkrs. Wife ended up giving me a Hawg-Wired RS400 amp for Xmas, so out with the old & in with the new. No complaints regarding this amp.
Four-channel, 4-ohm (only) amplifier with 75 Watts x 4 @ 4-Ohms RMS power rating and 300 watts RMS total power
Designed for stereo front/rear systems that require little space--just 1.53 x 4.25 x 6.75 inches
High- and low-level inputs with variable 4-6 volt hi level DC offset voltage input turn-on control
Selectable 80Hz LP/AP/80Hz HP filter @ 12dB/Octave
Discussion Starter · #4 ·
They don't come with a mounting bracket. Just use Velcro or buy aftermarket that's made for a motorcycle.
wiring
Is it just the amp or does it come with the wiring harness too. Does this amp require rca jacks. or can you plug into the amp with speaker wires. Interested for sure
Discussion Starter · #6 ·
It has the plugs that go into the amp and you hard wire your speaker wires to the plugs and your power into the other plug. I'll add pics of it tomorrow sometime.
