1 - 17 of 17 Posts
Hey guys, wondering what weight oil you are running on your RGU? HD-is not much help, they have a screaming eagle weight...haha Joke. Was wondering about a good BelRay or Other Synth oil weight. Ride 2 up most of the time. Was thinking 20 weight. Thoughts? BTW 13 RGU with 34K miles.
actually, they have 2 screamin eagle weights. there is screamin eagle heavy, and screamin eagle race.
I am running the heavy. I like it. some folks think it is too heavy and mix it 50/50 with stock.
do not get the race. if you do, it'll feel like concrete. pretty much for track use only.
+1 that's what I'm running, 50/50 mix
Stock is supposedly
5
SE 10
This is what I put in rear shocks,
Happy loaded
Fronts, over 10 too much on FLT
I Agee with Reds :surprise: Anything over 10, is was too stiff for a touring bike.
I run straight Heavy weight oil.... world of difference over what they come with
Thanks Guys, I will try the Shock Therapy Suspension Fluid #10 Medium...Second questions is How tough is the Job. Do you need the 1 3/8 open end wrench to get the caps off?
I run SE heavy... greatly reduce the dive for me
Sent from my SM-G955U using Tapatalk
Thanks Spazz- is the SE heavy 10 weight? how about the comfort did it make rougher
I can't remember the weight... the bottle says HEAVY on it
I would not say rougher... but stiffer, yes
I put in Race Tech Gold emulators with progressive springs and stock fork oil and it's a world of difference. Way better than increasing the oil weight.
Thanks RG cruiser Just trying to make it through this summer with the heavier oil that will help with the dive- just drives me crazy. Then Im thinking mono tubes or something like you have done.
What is the budget for them springs and emulators.
1 - 17 of 17 Posts
