1 - 13 of 13 Posts
So, I'm adding lowers to the FW. That's solves where to out the speakers. I have my BT2180 amp and wiring. Now, how to get music without an actual head unit. I'm sure there is bluetooth options. I just cant seem to find what I need. Bluetooth controller that goes right into the amp use my phone for music. I may mount the phone on the bars and then I have my GPS back.
Any help is appreciated.
I use a Ram mount and a Bluetooth speaker on my Dyna. I think you’ll get better sound if you go with something mounted up higher and behind a windshield.
I know the 13 CVO Road King had powered speakers in the lowers but I’m not sure how they worked.
The CVO King has an iPod in a saddlebag and an amp in the other one.
Sent from my XT1710-02 using Tapatalk
How is the IPod controlled?
Hand controls like a regular radio which brings up a great question. There has to be some module somewhere that bring everything together. I guess if I get bored, I can go through the wiring modules on Ronnie's HD site to figure that out.
Actually that’s pretty cool. I knew it had speakers but that’s about it. Must not of worked very well, they only put that on one year right?
Found it on Ronnie's. It's an interface of some type. Pretty cool.
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?Type=13&make=hdmc&a=938&b=68&c=0&d=2013 FLHRSE5 CVO ROAD KING (PG) SOUND SYSTEM
RFG, definitely reach out to Mike at biketronics. I doubt you’re the first one that has asked, he may have a solution sitting on the table or at least he may know who makes a converter to go from an iPod or phone output into RCA inputs.
I think I found it.
Kuryakyn RoadThunder by MTX Bluetooth Audio Controller
Turn any smartphone or mp3 player with Bluetooth capabilities into the ultimate mobile sound system. Wirelessly connects your Bluetooth-enabled device to Kuryakyn RoadThunder Speaker Pods, The Sound of Chrome speakers, or almost any other self-amplified speakers. This universal Bluetooth audio controller replaces the head unit and is easy to install.*
Features:Compatible with most Bluetooth devices, including Android and iPhoneEasy to install with hassle-free auto pairing and five front panel touch controlsIncludes two adjustable bar mounts: 7/8" - 1" and 1 1/8" - 1 1/4" diameterIncludes power, ground, and output connectionsDurable, weather-proof design
https://www.revzilla.com/motorcycle/kuryakyn-road-thunder-bluetooth-audio-controller
I think I found it.
But you’re looking to use your amp correct?
Sell your BT2180 and buy an AMP that already has a built in bluetooth receiver. Soundstream, Infinity and JBL all make at least one model AMP that already has a bluetooth receiver built in.
The only other option I know of (and this one is dependent on all of your players having a 3.5mm analog jack output) is to use a 3.5mm TRS to RCA adapter and plug the player directly into the AMPs RCA inputs. The main problem with this approach is that your player may not output enough voltage to properly trigger the AMP RCA inputs, or if it does the volume will be really low.
In that case you would need to add a line driver between the player output and the AMP input.
Yes. My amp and speakers. That controller says any powered speakers. My amp would be the power.
I'm going to call biketron9cs. And ask.
I just use a Y adapter to play Pandora off my phone running into my Preamp on my home stereo. I would assume it would work on a mobile system too.
1 - 13 of 13 Posts
