1 - 16 of 16 Posts
Who has both, how you like it, do they both perform well together for touring and what brand or model you have? Thanks.
Q, I have the Monroes out back and air over oil. No pistons or springs up front. It rides alot better than it did when I had the Bimba cylinders with springs. I run thefront at 70-80 psi. No issues so far. Should be pushing 1000 miles on the air over oil this weekend. Best part about the front is it only cost about $40. Just new seals and a quart of heavy oil.
Subscribing to this one. I have the Monroes in the back too. It would be cool to see what I can do to the front end
Torqu, do you still have a gauge molded in your tank dash? If so, what is it for..
I've got the dual air gauge in the upper gauge hole. It's actually pretty cheap and has worked pretty well. It's a Glowshift gauge.
If i could've found a digtal gauge set that illuminated in yellow or amber i wouldve got it. The blackout gauge look is nice..
No Q, I don't have anything molded into the console. But you may have started a winter mod.
My bad. I saw someone with a setup like yours with that mod.. it was nicely made. It was molded in the stock dash.
Torqu, I'm going to hit you up later on your air over oil set up.
No problem. Jr1000yarder from CB turned me on to this and he's running a 30"
Q. I think I saw that build over on CB. It was a RK build where the dual air gauges illuminated thru the CVO dash, correct? That was a slick setup.
This is good info as I'm also considering air front (mainly air over oil) when I go 23.
Yeah, it's was a well thought out design. Looked killer.
That's just the rear. I would bet they are using Monroes or the Gabriel shocks. No front air ride option.
1 - 16 of 16 Posts
