Seems the front brake light switch is going on the lamb! It's not broke it just works every now and then! I took the switch housing apart to make sure the wedge was behind it and all is fine there! My question is can I splice in a new switch or do I have to take the handlebar apart to do the install! I have drag specialties hand controls and switch housing and 14 buky malos?
Yes just pull the housing apart and splice in a new switch. Make sure you put a piece of folded up paper or card board between your lever and the perch, otherwise you will end up buying a second new switch.
What's the oem part # on that switch ?
Can someone elaborate on this? I had an issue with my switch in the past. I can't remember exactly what I did but I don't think it involved paper products. Any pictures of what you mean? Or are you just talking about during installation?
Discussion Starter · #5 ·
He is basically saying to depress the brake and put something in between the lever to keep from breaking the switch! It can be thick cardboard or I use the ends of a plastic tie just anything to fit in there to keep the brake lever from contacting and breaking the switch while you are screwing with the hand controls!
You put the paper ir card board in the lever to depress it while you mount the kever and perch back on the bar. The part of the switch that comes in contact with the lever is hallow plastic and it will mar or break through easily.
