1 - 4 of 4 Posts
My indy ordered Drag specialties 1741-2512 for my 12 road glide custom. Should I have to modify the mounting block that the bolt runs through to accomodate the alignment pin that is mounted on the bike next to the hole?? It will not sit flush unless I grind a small indention into the block for the pin to sit in. any help appreciated
Any word on this? I'm in the same situation. The Drag Specialties lines don't accommodate this pin on the 2013s. Can we just grind it off?
1 - 4 of 4 Posts
