1 - 14 of 14 Posts
Looking to upgrade front end..Progressive mono tubes, Arlen Ness lowers and boots. My question,..is it necessary to remove the inner fairing to do this??
No. Just the outter fairing, ignition switch, insturment natchel, front fender and wheel,.....
Lots of posts in suspension to assist and video too. Not hard to do if you have proper tools. Take your time!
No need to touch inner or outer fairing , if your just doing Monotubes & Cow bells.
You only need to remove your nacelle. This is me changing out the triple trees and forks on a 2011. I never touched the fairing, no need for it. There are better options available for your bike.
Thanks!!
Once again,, THANKS GUYS!!!!
I will be doing this project on Saturday. I will upload pics as well.
Front End Complete
Finally got all of my parts and completed the install on Saturday. I will be posting pictures and video as soon as I get it edited together. I only ran into one minor snag. The left side bottom Allen bolt stripped when I tried to remove it. I had to go to 3 different places to to get an extension and easy out that would fit in the small hole at the bottom of the fork. I SHOULD HAVE STARTED AT HARBOR FREIGHT!! I could have saved myself 3 hours of driving around. Even the replacement bolts I got from the dealer seem a little shallow so if you are doing this be careful to get a good bite straight on so you don't have the headache I got :) Without that snag this would have been a 3 hour job max!! Everything else was straight forward as posted on other videos. No problems with fairing at all, only instrument cluster needs to be removed. I was able to get the fork cap bolts off with a crescent wrench. My handle bars did not allow for use of the 1 3/8" socket ( I could have moved the bars but the crescent worked fine) I am going to show some of the tools I used and made in the install video. Again thanks to this Forum for reducing the "pucker" factor in tackling these projects!!!
Video and Pics as promised
Nice job, looks great. I wonder how those sliders will hold up to nicks & chips from road debris. I was going to go powder black on the sliders and those cow bells but decided not to , due to nicks and chips.
Thanks, I will keep an eye on wear and post results after time. Anything is better than stock though!!!
I chromed the sliders on my FXR years ago. Still perfect. 50K is a guess.
Looks great, did you go with a drop?
I have the same forks with about 7k on them and no issues so far.
Discussion Starter #14
Standard Version not lowered
I wasn't sure how long it would be before I upgrade to a 21" front tire so I wanted some flexibility. I spoke with Progressive and they said I could just leave out the pre-tension clips and I could achieve nearly an inch of lowering which I did. I did not take any measurements prior to install, but looking at the before and after pictures it does appear to be slightly lower.
1 - 14 of 14 Posts
