Front end riding issues
410 Views 6 Replies 4 Participants Last post by  Greg
I have a fat tire kit on my 15 road glide and I’m not sure if that has anything to do with my problem but the bike tends to pull back and forth from left to right. It’s a very slight pull but enough to be annoying and I feel like people think I’m all over the road idk if the fat tire kit is the issue or not but any suggestions would be appreciated
Also I have front air ride if that helps narrow anything down
Last time I experienced this, it was due to a worn out rear tire. The tire was more squared than rounded. Did you install this kit?
Reactions: 1
First place I'd go is neck bearings.
Reactions: 1
Who did the Fat Front Tire Kit and when was it done and when did the issues start?
All good info has been given, worn out tire, neck bearing. Could also be wheel bearings.
Best of Luck and Keep Us Informed.
Mike U.
No I did not install the kit and the rear tire is brand new as for the front I’m not sure how old it is but is very new looking
Reactions: 1
Mike U.
I’m not sure who did the kit but from what I was told neck bearings were just replaced my next option is to go to Harley and have them look into it because from the posts I’ve seen this should feel like I’m riding on rails
Neck bearings being replaced incorrectly / not adjusted correctly will do what your describing.
By you not knowing is reason enough to check all and not go by " I was told " JMHO
Hope you get it sorted out.
