Easy, use your head
Purchase an oil level gauge. Remove the steel measuring tube and bring it to your choice hobby store. Find a stiff tubing that comes in 36". Buy a small piece of clear tubing as an adapter. Insert the long piece (one foot or so) over the syringe than try to put in the small stiff tubing inside of the flexible clear tubing. If the small stiff tubing is too small than purchase a small piece of tubing to act as a sleeve to take up the room.
* Install the metal ring around the small stiff tubing.
* Remove the nacelle by the 4 torxs bolts on the side, key switch, and spedo. Set is aside.
* Front Wheel off the ground, than:
@ remove the top chrome bolt (picture below) on the fork tubes (1986~2013 only)
@ Stick the small stiff tubing in the bolt hole and keep sucking until you find the oil level than slide down the metal piece on the small stiff tubing until it hits home on the triple tree to mark the fork oil level.
@ Measure from the bottom of the small stiff tubing to the metal piece using a Grip Jumbo Aluminum Caliper — 24in. Jaw, Model# 59070 found at Northern tool or maybe HF. Mark it down in millimeters & impress your friends.
@ Add some oil by loosing the metal measuring piece and measure from the bottom what oil level you wish to try, tighten the set screw. Suck some fork oil out of the bottle and expel it into your fork tube. Than suck the excess back out until you sound like a kid at DQ.
Repeat the same procedure in the other fork but get both forks the same level.
Tighten the bolts back in the top of the forks but leave the nacelle off and ride to test.
Adjust to suite.
Good luck, it works. :surprise:
http://www.roadglide.org/images/RoadGlide_2015/smilies/tango_face_surprise.png
