1 - 2 of 2 Posts
Help... the holder bolt thread shaft sheared off when I loosened and retightened when I was reinstalling new rubber on front wheel. I over torqued it! Is the threaded shaft removable and replaceable. if so is it a left thread to install. I hope I don't have to weld it and re-thread.
Help...
Are you talking about the two threaded studz that come out of the bottom of the slider ? If so , yes . They come out and can be replaced.
Use heat and a double nut to remove. If you dont have enough thread , weld a nut on to remove.
1 - 2 of 2 Posts
