I noticed the other day my front right turn signal was out,upon replacing the bulb I noticed it was loose. When I checked it I found out the threads are stripped inside the signal housing. Thanks Longhorn HD,they are the ones to pull them off while working on a short in my cruise control. Either way I need an OEM Right side front signal, if anyone out there knows where I can get on. Maybe a wrecked bike or a take off set.
2021 Ducati Multistrada V4S
You can always helicoil it. Those turn signal housings are notorious for striping. Don't be so hard on the tech as you are on MOCO for the poor design. Thank goodness the new ones aren't the same.
https://www.google.com/webhp?ie=utf-8&oe=utf-8#q=helicoil&tbm=shop
I had that issue as well. Following some advice from this forum, I mixed up some JB Weld, used a small stick to coat the inside of hole in the signal housing and threaded the stud back in. Let it set up overnight and reinstall. No further issues.
Discussion Starter · #5 ·
I really thought about using JB Weld but I bought a used pair off of ebay instead. Thanks for all the input guys.
Reactions: RGKen
