FS: OEM 2-1-2 head pipe off a 2012 Harley touring bike that has had the catalytic converter removed. This pipe should fit 2010-2013 Touring bikes. I personally gutted this pipe and had the local shop re-weld the pipe back together. It is the "window" type cut so you don't have to worry about the heat shields not fitting it correctly. I also have a set of chrome heat shields that can go with the pipe if you want them. I switched to a 2-1 system and no longer need this head pipe. $100 picked up or I will ship on your dime.
Out of curiosity where are you located?
I will find out for sure. Guessing in will be $15-20 range. I use USPS to ship stuff. Seems to be the best price.
