EFI tuning and Exhaust Expert
Here are some results from some recent 107 development and testing we did. Note this was a full effort, fully developed build by Fuel Moto with assistance from several other key partners including Gary Williams & Bobby Wood. The charts in this thread are a result of several weeks of work & dyno testing/swapping/building/modifying various components
2010 FLHX test bike
FM 107" IC cylinders
custom MTC pistons 12.5 comp
Gary Williams cylinder heads
Wood TW68G-7 cams
Darkhorse lower end with H beam rods
SE58mm TB (modified)
Jackpot XXX exhaust
tuned with Dynojet Power Vision
PUMP FUEL
Run Data:
RunFile_019.drf: 63.04 °F 29.15 in-Hg Humidity: 7 % SAE: 1.01 Average Gear Ratio: 45.87
s RPM x1000 hp ft-lbs
0.25 2.60 40.92 82.70
0.45 2.70 43.69 84.98
0.63 2.80 47.93 89.89
0.79 2.90 53.70 97.23
0.95 3.00 59.97 104.97
1.10 3.10 65.32 110.64
1.25 3.20 69.93 114.76
1.39 3.30 73.58 117.11
1.53 3.40 76.31 117.87
1.67 3.50 79.18 118.82
1.81 3.60 83.00 121.09
1.95 3.70 86.13 122.27
2.08 3.80 89.02 123.04
2.22 3.90 92.66 124.78
2.35 4.00 96.43 126.61
2.48 4.10 98.54 126.24
2.62 4.20 101.84 127.35
2.75 4.30 104.79 127.99
2.88 4.40 107.16 127.92
3.01 4.50 109.53 127.84
3.14 4.60 112.36 128.29
3.28 4.70 114.60 128.06
3.41 4.80 116.91 127.93
3.55 4.90 119.25 127.82
3.68 5.00 120.65 126.73
3.82 5.10 122.42 126.07
3.96 5.20 124.68 125.93
4.10 5.30 126.23 125.09
4.24 5.40 128.41 124.89
4.38 5.50 130.11 124.25
4.52 5.60 132.05 123.85
4.66 5.70 133.81 123.30
4.80 5.80 136.46 123.57
4.95 5.90 136.31 121.35
5.09 6.00 138.90 121.59
5.23 6.10 141.99 122.25
5.38 6.20 143.36 121.44
5.52 6.30 145.53 121.33
5.67 6.40 147.25 120.84
5.82 6.50 149.63 120.91
5.97 6.60 151.96 120.95
6.15 6.50 61.60 49.53
6.34 6.40 34.99 28.57
6.42 6.30 -6.11 -5.31
MAX: 6.42 6.60 151.96 128.29
MIN: 0.25 2.60 -6.11 -5.31
Why do you hate me!!!! LMAO!
Just came to a decision on what I was going to do and now you post this.. :eek:
Just like a gorgeous, sexy woman winking at me and the driving off....
It turns me on, but I know I am not gonna get any of that...:(
Great output from a 107, but do you foresee any demand for a setup like this? Unless someone was racing in a class with a displacement limit, wouldn't you expect someone investing that much to go with more cubes while they were at it? To that point, have you done an equivalent build with your 117 kit?
That's a Bad Boy there! Not your grocery getting 107" engine for sure .:eek:
This shows the potential of the FM XXX exhaust, I like it, stainless, ALL the O2 bungs for the DIY tuners and use stock heat shields.
I bet this pipe setup would be right at home on a stout 124.:)
Keep up the good work Jamie
