1 - 14 of 14 Posts
I recently purchased this Fuel Moto AIM Variable Pressure Clutch and have traded in my bike so I removed it. It works great. If you are experienceing any clutch slip and do not want to add clutch pull this is the solution for you. Everything is here and it installs in 15 minutes. $225.
I used the stock spring 2012 Streetglide w/ Woods 222. The Fuel Moto/AIM clutch is the most cost effective & most powerful kit available to upgrade your H-D stock clutch. Developed by Fuel Moto with a specific weight combination to suit our engine packages. Supports 130Hp/130Tq with OEM spring, or 150Hp/150Tq with optional heavy duty spring. Up to 7% reduce clutch lever effort. Up to 40% more additional pressure when locked up.
1 - 14 of 14 Posts
