If my Vance and Hines Fuel Pak quits working on my 2013 road glide, can I simply unplug and then the bike will run long enough to get to dealer.
Short answer is yes. I had Fuelpak take a dump, the bike ran ok but hot (lean) with a high flow air cleaner and true dual and pipes. If your bike is stock, not stage 1 should be no problem at all.
Thanks for the replies. I was just curious if it went out on the road could it get me home or to dealer. I have a stage one with a/f and pipes and no cat.
I had 32K on my last Fuel Pak with 0 issues. I wouldn't worry too much about it as long as the connector is sealed good.
