Update. Can’t get 2 Biketronic BT4180 amps into the fairing.
BUT
The cubbies are 4.250” aka 4 1/4”.
They will support
Diamond Audio Micro4V2 in each.
Cerwin Vega B54.
MATTS Audio Pro amp MD4110
Now which ones to use in cubby.
Like CVO I’ll put the BT4180’s into each bag.
2 DSR1’s in fairing.
That would work.
Have you tried using a Lex Rivera amp mount? It allows 11 1/4" long 8" wide and 2 1/8" tall.
Yes I've used it before, but not for 2 BT 4180's. Here is a pic of it with a Soundigital 1200.4:
The Soundigital is almost twice the size of a 4180, so 2 MIGHT fit on the tray. The next time I get one I'll try it as I have 2 4180's and a 4250 in stock. It MIGHT also be possible to fit one under the radio and one on top of the headlight using that tray. I know you can fit a Soundigital 800.4 on top of the headlight, and the dimensions are very close to a 4180.
I took some measurements of the 4180's. It would be tight but looks like they would fit side by side. I also set an Arc Moto 600.4 there for comparison.
