1 - 4 of 4 Posts
I know, I know, There is probably a post hidden in a 200 pg thread to answer this question but...... I am installing gabriel air shocks on the rear of my 11 FLTRX, I want to run 1/4 air line, in blue... lol I have found the 1/4 air to 1/8 npt ptc fittings but can anyone direct me to where i can find the fitting for the shock bodies themselves
The fittings on the Gabriel shock body are already welded on the shock and you use the supplied plastic nut and rubber o-ring. I don't believe you can change the line size into the shock. Maybe the Monroe shocks have a different type of fitting, but the Gabriel shocks fittings are definitely not replaceable.
Charlie Wooton
There is a guy on chopped baggers named charlie wooton I think his screen name is promod66 he can hook you up
1 - 4 of 4 Posts
