On my 08 RG . Every time I take the windscreen off it is a pain or impossible to get screws 2 and four back in . I just purchased another screen and it is even tougher . It is like the screws arent long enough . I believe I will try longer ones but is there an easy way to do this ? Thanks in advance for your insight to my issue . Mark
some one on here you can find aftermarket windshield mounting hardware that comes with longer screws and heavy duty inserts they are worth the money, i got a set included when i bought my freedom shield.
With the well nuts that were on my 91 FXR when a year or more old did not line up correctly due to the rubber being distorted, probably from me over tightening them. I recommend changing them. MadStad has some that the heads are oversized to prevent them from getting pushed all the way into the fairing.
I used to screw the well nuts onto the screws through the windshield. Not tight just snug so its touching the windshield and not bulging. I would then just push the well nuts into the holes windshield and all. Then tighten as normal. I always kept a handful on hand and would replace them before the got all hard.
What he said^
Reactions: MarkL
Well , I didn`t believe you but desperation made me try it anyway . Worked like a charm , like super easy . Thanks ! Mark
