1 - 11 of 11 Posts
hardest part is probably going to be not losing the screws and taking off the clutch side grip (b/c it's glued).
I thought that the new left grip is now a "Slip On" grip. The older ones were glued on the handlebar.
If your question is regarding running the TBW internally, it can be a bit of a PITA. I have HeliBars so only a portion of the TBW is inside. There is a post on this forum by a member named Donk. I followed his instructions in his first post where the wiring was all external and it was a huge help. I think he has another post where he shows how to wire internally. If you're only installing grips it should be simple. You just have to make sure the grips you buy are designed for TBW and they'll practically install themselves.
Had the stealer do it on 1K service. Charged me for 20 minutes. No worries about TBW.
1 - 11 of 11 Posts
