As someone from Toledo, never thought id see TDS mentioned on this forum and this is the second time. He added some speakers on my bike and tuned it. Getting ready to get a stereo installed and possible more speakers. Thanks for supporting a small shop in my town. He does good workHey all.
I haven't posted in awhile and thought this would be a good time to talk about a recent install.
2017 RG Special.
In 2017 I installed a Diamond Micro2 v2 and D&D speakers.
The amp is fine but I've driven the speakers pretty hard and decided to replace.
I can't complain using the D&D for 6 years.
Last knight we installed these Ground Zero 6.5 and I'm pretty impressed with the sound and added base.
We had to modify the speaker pods a little.
Once finished I added sound deadening.
I purchased these at TDS car audio in Toledo OH.
Just curious what the dsp will do and if you already had them at 200w, why turn them back to that after adding?I looooooove my GZ's! how many watts are you sending to them? I tried mine at 200w and they were way too bright for my liking, I toned them down to about 150w and turned the xover down, and the midrange is perfect and the highs are just right. maybe I'll add a dsp and pump them back up to 200-250w
when using the stock headunit, with a flash, you lose control of the treble and bass settings, therefore when pumping a lot of watts into your speaker of choice, the highs can be very bright and overbearing.Just curious what the dsp will do and if you already had them at 200w, why turn them back to that after adding?
