1 - 3 of 3 Posts
Hi John am installing your 250watt amp on an 11 roadglide custom. Quick question:
Have located the ground stud on the frame near the battery but can't seem to get at it with a wrench. Do I need to remove the battery etc to be able to get to it or is there some trick or tool you guys use? Or is there some other point more easily accessible I can attach the ground?
Any pointers would be appreciated.
Cheers,
JED
Discussion Starter #2
NEVER MIND! Just realized it's a 10mm - I've been trying 3/8. Combination of bad eyes and and even worse lighting.
Cheers,
JED
1 - 3 of 3 Posts
