Hey guys when adding an aftermarket amp on a 2015 road glide special do I need anything to retain the factory handle bar controls. Head unit is the 6.5 touch screen
What setup are you installing? Usually when you add an amp you are just amplifying the speakers, not changing any other operating characteristics.
You need to swap out the speakers too if yours are stock. Amps don't affect controls. I went with the Biketronics Amp/Speaker kit. Plug and play easy install and it sounds really good with just 2 speakers. Your never going to get great bass on a bike so don't even try. Go for good, clear sound at highway speed.
The plan is to install arc audio 600.4 with 6.5 components upfront and 4 6x9’s in the bag. Also do I need 2 BT 355’s
Check with Arc or maybe someone that has a similar system will chime in, but I believe they have their own method of addressing what the BT355's do.
