2011 RGU is the Harley amp#76000169 worth buying . I have J&M speakers in the front Rockers . rear are Harley
Where can I buy the wire harness that comes with amp . The amp is used and he lost the harness. Dealer said that harness only available with new amp
What's the asking price, and what are the specs for the amp?
I just looked it up..... $400 for a 160 watt 40 watts per channel 4 channel amp. .... you can do a whole lot better, personally I wouldn't consider it, IJS..........
Sent from my SPH-L710
If you're talking about the rear speaker wiring harness, most dealers have those in stock for about $100. It connects to the HK in the rear to hook up the rear speakers and amp. When I had my HK, I didn't use it I just hooked up 4 wires to the proper locations in the rear of the HK. Then ran those to my amp. Worked just fine.
Yep go after market.
Sent from Motorcycle.com App
What he said. . . .
Only paying $100. plus $50. for dealer set up but need harness .what would be good after market amp. Thanks for the help
For less than $150 you could get a Sound Stream or Rockford PBR amp with twice the power of the HD amp.
