Not true at all. Bigger pan and more oil means the oil stays in the pan longer before being circulated back through the motor. This adds net cooling capacity to the system and will result in a a 15-20 degree drop in max steady state oil temps. It is a dry sump system, so it is more like an oil tank versus a pan, and it is exposed to the slipstream under the bike as well.
