1 - 1 of 1 Posts
I have the Harley Stage III for M8 setup for sale. 107CI to 114CI NIB This is brand new, only opened to inventory. I was planning to install on my 2018 RGS but leaning toward the 2019 CVO instead. It is 5 cents short of $1,700 from Harley
$1200 shipped Conus
Also have Screamin' Eagle High-Flow Injector Kit - M8 5.5 G/Sec - retails for $149, will include for $100
https://www.harley-davidson.com/store/milwaukee-eight-stage-iii-kit-–-107ci-to-114ci
From the Harley website:
Delivers up to 39% more power when compared to the Original Equipment engine configuration
Delivers increased throttle response throughout the entire RPM range
Produces flexible roll-on passing power without a required downshift
Delivers excellent stop-light to freeway speed on-ramp acceleration
Retains Original Equipment Factory Warranty
Includes 4.075" Bolt-On Cylinders, Forged 11:1 High Compression Aluminum Coated Pistons, High Performance Piston Rings and Tappets, SE8-498 Cam, Performance Valve Springs
Includes Multi-Layer Coated Head Gaskets, Cam Bearing Upgrade, High Capacity Clutch Springs (1200N), most necessary gaskets and seals
Black with Highlighted Fins - Matches Original Equipment Non-CVO models.
1 - 1 of 1 Posts
