21 - 40 of 42 Posts
Not sure if it's any different for the newer bikes. But with my Tourpak I have the LED Rear light bar, tourpak speaker pods, AirWing LED brake light, and one extra spot to add aux charger if I want to.
I only have 1 big plug and 1 small plug to disconnect when not using my Tourpak.
YB
Large Plug
Small Plug on longer lead (that's on saddlebag lid) goes to module for R,B,L plug.
It would leave a long harness that I would have to curl up, and the quick release mount didn’t have a shelf for the harness like the solid mount so I had to wrap the harness to keep it from rubbing on the fender.
Actually the harness, (and longer lead) is attached to my QD Tourpak mount. No wrapping at all for me.
Either way, I thought it might help you out.
YB
This is the Plug that you can see under my solo seat. (Excuse the black marks on the clear protector, it's from
my 2up seat.)
Still got the harnesses (lighting & audio) to coil up under the seat, but... I made a "shelf" out of plexiglass to keep them off the fender using velcro straps. The notch that the green arrow is pointing to is important to get to the rear seat bolt easily :p just took a few minutes to cut out, drill two holes, smoothen all the edges and mount.
The HD Signature sires light is the only sequential TP light on the market at the moment.
Really?! Badlands doesn't sell sequential light modulators? Huh You must be a parts guy....Suggesting that the 24 wiring is wildly different than the older bikes. It's harley we are talking about here. I wouldn't be surprised that the fitment on a website saying it doesn't fit a 24 is because they haven't updated their fitment. But I wouldn't know.....I don't work on motorcycles for a living.
I don't think the Badlands unit works the way you think it does. I didn't anything about wiring, the 24 Road and Street Glide don't have rear mounted antennas. Unless I'm mistaken the OP has a 24 Road Glide, so that is what I'm basing my comments off of. Tour Paks haven't changed so the Signature Series light will fit the current Rushmore Style Tour Pak.
Correct the tour paks and lights are the same. The original complaint was that the light wasn't a modulating type, he was going to get a refund for. I was offering up a way to make it modulate. Once again specific badlands unit works as a modulator, and you can also get custom dynamic modulators that are even more customizable with what you want the lights to do. But again what do I know. You're clearly the expert here.
Discussion starter · #27 ·
After talking to Harley on the phone this morning, they said to take it back to my local dealer for a 100% refund, which I did.
The Harley parts rep on the phone said some dealers and their policies do not allow electrical items to be returned but in this case she gave me a reference number in case the dealer balked, which they did not. She agreed the listing was previously misleading.
I found a mint 23 RG Limited "pull" LED (with side LED's) from a guy who changed his LEDs to smoke. $122 for all 3.
All is well.
L2
Discussion starter · #28 · (Edited)
I'll look into them. I was after "sequential" turn signals on a Tour-Pak wrap around LED bar, like the old T-Birds. Not a straight modulator with extra lights. Maybe the aftermarket modulators will do what I want to do, I'll do some research.
L2
Would the HD#67801129 not do what you wanted it to do? Its the actual red HD tour pack light bar with sequential turn elements... the fitment is what I am not sure about, it says:
"Fits '14-later models equipped with King Tour-Pak (except models equipped with CB antenna). For models with AM/FM Antenna, a separate purchase is required of Internal Hidden Antenna P/N 76000862 (except models already equipped with Hidden Antenna and '23-later FLHXSE, FLTRXSE, '24-later FLHX, FLTRX and FLTRXSTSE). Will not work with new jumper harness."
I do not know what those last 7 words refer to, but if the other light bar you returned had the right connector on it and worked on your bike, then I think this one has the same connector on it... then its just a matter of a BCM setting, on some bikes to get it to function correctly.
Discussion starter · #30 ·
That ad is the exact same ad and price as the one I bought, until they changed the ad a few days go, lol. They copied and pasted that description.
L2
I just realize the light you bought, HD #67801541, is made to work with the required harness for your '24 Road Glide, but they had the wrong advertisement posted for it (about its ability to do sequential lighting)... and the one I posted does the sequential lighting, but won't work with your bike, or the required harness.
Yep. Feel free to contact me directly if you need more insight.
Discussion starter · #33 ·
And therein lies the heart of the matter. And the kicker is the actual light bar part number they sent me with the 67801541 is/has been the same for years - 67800093.
L2
Ok, soooooo the 67800093 is the same ole light bar thats its always been, like the one that came on my '23 RGL, only under HD #67801541 it is for a '24 RG and requires using this "special" harness 69203400 ($150), that looks to have a 'module" in line (the "box" the arrow is pointing at). Which, except for the module that harness is very similar to the $75 harness in my tour pack.
So that would mean physically the HD #67801129 light (the one that actually does sequential turn signals) and is for '23 and older model bikes would also "physically" fit and plug in to that new harness... but the pin out of the connector, and what's coming out of that module on which wire and when, would have to be figured out, because #67801129 says it doesn't work with that new harness... or will an old style harness work if pinned out correctly???
I do know that the #67801129 sequential light bar has a setting in the BCM that has to be set correctly to get the light to function correctly on the '23 and older bikes. By default it is usually set right, but a few have put that light bar on their bikes and when applying the brake the light just goes bright for a millisecond... if it does that, the "fix" is to have that one setting changed in the BCM and it works as advertised. The setting has to do with "Dedicated Brake Light" or "Turn Signal Lamps", this is the setting in Diag4Bike.
But I ain't buying a '24 to figure out how to make the sequential light work :p but it may be doable IF that option is still in the BCM, or if the default setting is "right", on the new BCM in the '24's... its just money
But unless I just had the sequential light bar sitting around from a previous bike, I'd just wait a minute, and they'll probably have the sequential light available, with its own special harness to make it work... or CD or someone else will come out with a module for it.
The 67801128 light (same as the one reference above but the smoked lens instead of the red) works partially on the '24 with the harness listed above (69203400)...the running lights and sequential turn signals look great but the brake lights give a very brief flicker at most.
Discussion starter · #37 · (Edited)
Well the 67801128 sequential light bar does not completely work with the new 69203400 harness, and the original 67801541 light bar (bait & switch) that does work with the 69203400 harness is NOT sequential. It's also not worth $373 plus another $145 for the harness. Not when you can get an older light bar pull for $100 or less.
As you know the 24 RG's use a new 12 pin connector under the seat, thus it's a new connection point not previously available (only 23 CVO). I should have in my hand the non-Harley "fix" to the problem of putting a regular (non-sequential) LED light bar on a 24 tomorrow. I'll post my findings tomorrow night. There is no fix for running the Harley sequential bar (red or smoke) on a 24, yet anyway. Like you and another have stated, the brake light only momentarily flickers.
"Will not work with new jumper harness"
L2
When you get that light bar working, check when you hit the brake to see if the whole light bar goes "bright"(all the way across, skinny center section as well as the fatter turn signal area), or if just the skinny middle section (single row between the turn signal area). On the 14's thru 23's there is a setting in the BCM that will cause it to light only the center row bright upon braking, then the outer sections (turn signal area) are just Run/Turn... it is the same setting that causes the sequential to not work properly on the 14's thru 23's (see post #34). On those year models it's easy to "correct", although it takes diagnostic software to get to the setting. I had my '16 RGU doing it after I had been troubleshooting a different issue with some Electra Glow Keystone lights I had at the time... because I changed that setting, and it was an easy fix.... I do not know if the setting even exist in your 24's BCM (probably, I would think) or what the implications of that new connector/harness is on these lights. I'm just mentioning it in case there's unexpected behavior with the light, so that maybe it can be checked to see if it may be correctable.
Discussion starter · #39 · (Edited)
Success. Everything is working perfectly on my 2024 Road Glide Tour-Pak LED project.
Tour-Pak wrap around LED Bar turn, brake and running lights - check
Tour-Pak side running lights - check
Tour-Pak turn/brake/4-way/running lights all working together - check
Saddlebag speakers pass through built into 12 pin splitter - check
Auxiliary power for a internal charging station - check
I've been waiting OVER two months for the damn Harley harness (no ship date given) so I bought three harness pieces/parts all on Amazon instead:
12 pin splitter - $78.90 - https://amzn.to/3TElzHj
6 pin extender cable - $11.90 - https://amzn.to/3VC140x
Tour-Pak wiring harness - $46.99 - https://amzn.to/4aD71hX
If you already have a Tour-Pak "internal" harness and 6 pin female to 6 pin female/male cable you only need the 12 pin splitter.
I was starting from scratch so I needed all 3.
JUST the Harley light bar 67801541 @ $373, side lights 69494-06 @ $138 and harness 69203400 @ $145 = $656
Versus:
2023 like new "pull" LED & side lights on Mercari @ $122, 3 harnesses on Amazon @ $138 = $260
And no more waiting on misidentified or backordered Harley parts.
A couple things worried me about taking the route I did after Harley changed their listing. Would the rear speakers and their connections "pass through" the 12 pin splitter? Would the brake light work without flicker? Could I save some serious money by buying a 2014 and up Tour-Pak red LED light (67800093) and red side lights (69494-06) "pulls" from somebody who probably wanted "smoke" lenses? Can I disconnect it easily without talking off the seat? Are the non-Harley wiring harnesses quality parts?
All answered yes. Hopefully my journey can save some a few $$$ and headaches. Life is good (and now visible)
L2
A few pics:
2023 like new "pull" LED & side lights on Mecari @ $122, 3 harnesses on Amazon @ $138 = $260
A couple things worried me about taking the route I did after Harley changed their listing. Would the rear speakers and their connections "pass through" the 12 pin splitter? Would the brake light work without flicker? Could I save some serious money by buying a 2014 and up Tour-Pak LED light (67800093) and side lights (69494-06) "pulls" from somebody who probably wanted "smoke" lenses? Can I disconnect it easily without talking off the seat? Are the non-Harley wiring harnesses quality parts?
L2
A few pics:
Good job bud. As frustrating as it is at times, where there’s a will there’s a way, and you found it!!
21 - 40 of 42 Posts
