1 - 3 of 3 Posts
I have a '10 RGC. I already have red LEDs under the bike that are powered by the Spot switch, so they can stay on with the ignition in the off position.
I would like to be able to do the Halo ring mod the same way, but im not good with electronics.
I still have my factory accessory switch that's next to the cruise switch. Is there anyway I could wire a hot and ground wire from the LEDLITZ lights to either of these switches so they can be on with the bike off?
Also, do these install easily with a mean mug?
(I don't want to run it to the headlight wires like many did in the Halo mod thread.)
Thanks for any help!
Discussion Starter · #3 ·
I wonder how hard it would be to wire it in with the others to the spot switch? Ive never done anything like that before. Id nave to pull fairing and take a look. If I wired the hot and ground to either the spot or acc switch, then I would not need to run anything to battery, correct?
1 - 3 of 3 Posts
