1 - 4 of 4 Posts
Ok I got the pinch bolts loose and the stem nut loose and I made a couple tools for the adjustment nut but it won’t turn I know it’s loose since I can move the washer underneath it up and down should I be able to turn the adjustment nut by hand with the tool?
No, tap it with hammer.
https://glide-pro.com/media/
i see from your other posts that you have a 2012. having done this on a couple of my bikes, a 2010 and a 2013, i can tell you to be careful. a little bit goes a long way. just a slight tap took my fallaway from almost 4 swings to less than 2.
Agree with skratch, easy as you go.....I went to Ace hardware and picked up a long piece of flat stock, bent it slightly at the 4-5 inch mark and it worked great tapping with a mallet.
Did you lift the bike up and support the front wheel when trying to tighten? has to be free to do the swing test, but supported when tightening...I used a hyd, car jack right under the tire
1 - 4 of 4 Posts
