1 - 9 of 9 Posts
Installing a 6 pack from HW that includes all the wires / harnesses.
I ran the power tonight back to the battery but the ground wire is only about 2 ft long from the amp.
I've read a few posts where people are using the mounting studs for the fairing bracket....
The instructions say to look for a ground wire on the neck, but I dont see anything.
Any suggestions?
D.
They probably mean the neck of the frame where the gas tank mounting bolts attach. That's where I ran my grounds from my amps. Just make sure you have a nice clean/clear contact with the bare metal.
+1, I used the same place, use a small file to remove the paint in around the hole and insure a good connection.
Sent from my SPH-L710 using Motorcycle.com Free App
It is on the Neck.
I can not to save my life remember what the heck side its on?
My instructions shows X-ACTLY where it is.
I've got 2 Amps grounded there w/no Problems.
I grounded mine to the fairing bracket as well... no problems yet.
Sent from my Motorola Electrify using Motorcycle.com Free App
fairing bracket as well. No problems so far (only been a few weeks, not much riding due to weather)
do you have abs? where the wire run on the neck theres a loop that the wires go through the bolt that stews in to the frame is where i put my ground wire.
1 - 9 of 9 Posts
