Worked fine for a few weeks, but now I get a crackle when I'm moving and if I have the volume over 3 dots. Doesn't do it when sitting still. ??
Sounds like a loose wire .
It almost seems like I need a filter somewhere. Like back in the day with a car stereo?
My thoughts are a ground wire as well. I had the exact same problem.
I also had the problem with the rca jacks out from my sony... ended up having to run the speaker outputs.
If you needed a filter, it would do it while sitting still or moving as long as the engine is on. If you sitting still and rev the engine does anything change?
