1 - 3 of 3 Posts
whats everyones thought on these speakers? twin audio recommended them to me and after trying them for 2 weeks they just don't seem to be loud enough using a 100watt per channel amp,sound is distorted a lot at volume levels,gains are set right,just fishin a bit for others opinions
I have the six pack system. Sounds pretty good. If u get them make sure your Advanced Volume Control is set to OFF! Also if you use a mp3 player, make sure your volume is set to halfway! If u don't do these two things u will blow the speakers. It just happened to me and I have been running them for at least 500 miles. Called Hawg Wired and found out that's what my problem was. They are gonna cover the speakers and crossovers this time.
I'm running an alpine 149bt so i don't have the abc and u thumb drive for music,download with exact same music my buddies are running on different systems which all sound fine
1 - 3 of 3 Posts
