1 - 17 of 17 Posts
I had the HD 103" stage 4 installed in my bike and I am still using my original SERT but the problem I am having is with the idiot running the dyno. The bike was on the dyno all day Friday and around 11am Saturday I get a call from the dyno guy saying my bike is done. I go pick up the bike with a trailer because it was raining upon getting there the tuner wasn't available he stepped out and won't be back until Tuesday so I payed for the service went out started the bike and loaded it in the trailer. When I got home I started the bike and let it run for a few minutes then shut it off then a couple minutes later I go to start the bike again and it WON'T START it will crank over and spit and pop once in a while but it won't start. I hook the battery charger to the bike to make sure the battery stays up and I try it again and if I play with the throttle giving the bike around a 1/8 of a throttle the bike would try to start. Letting the bike starter cool down for a hour I went to start the bike again and it started let it warm up shut the bike off try to start it and it just cranks, if I do the throttle thing I may get a pop or a spit out of the bike. Obviously The asshole that done the tuning doesn't know shit and it make no sense to take it back to him and I assume I will never get a refund from him and now I got to find a good tuner that knows how to tune the bike correctly and pay again. It really pisses me off and I may see a lawyer to see if I have any legal grounds to stand on but in the meantime I need to find a good tuner in Arizona or southern Nevada area and I am looking for recommendations, it seems that the HD dealers are the only one in the area with a dyno other then this asshole.
hopefully you can get your money back.....scenarios like this are why I spent the bucks for a good auto-tuner.I'm not racing so I really don't need every last bit out of it anyway.Just a good running bike.
Perhaps with the money you spent back in your pocket you might go that route? No question a good dyno-tune is really dialed in better,but it depends on the operator.
just an idea.
Was this done at a dealer or an indy? Just curious on that point, but in either case they need to make it right for you. You mentioned going to a lawyer, but I am pretty certain that the lawyer would suggest you give them a chance to make it work for you.
Hope it all works out - I am sure it will, just frustrating I know.
Chief Safety Ossifer , CEO Doofus HD
+1 -- hold their feet -- or face -- to the fire !!!!
I agree. Give them a call and a chance to make it right. And if they won't give Steve at GMR a call he'll fix you up for sure.
Sent from my DROID4 using Motorcycle.com Free App
It is a long story but I am trying to make it short. I already gave this guy a chance I had him do the work on the bike when putting the stage 3 together and when he got done polishing the heads he used the same valve seals even though they were the seals that came with the new heads, the result was that the bike blew (not a puff) blue oil smoke out of the exhaust when started then he took the heads off and replace the valve seals, even now after he replaced the valve seals the bike blows blue and black smoke when I can get the bike started (the bike only starts when it is cold now), I originally had him do just the heads and 10.5-1 pistons and he insisted that the 255 cams in my bike would be good, then after no improvement in performance after the first dyno tune he then wanted to go with the 259E cams as I suggested to him when the build first began and to make it a complete stage 4 we went with the Throttle body and injector upgrade as well. This guy could not do a good dyno tune on the first upgrade and blamed it on the cams (which is understandable)and then he totally screwed up the second dyno tune, this guy is truly a bad apple and to give him another chance to screw up my bike would be foolish on my part the only other foolish thing I did was to walk into his shop listen to his line of shit and let him do the work. This is the guy who is did this to my bike and he is a total rip off IMO. www.kellysperformancespecialist.com
U
Guest
After or hell before getting your bike returned go file in small claims court against him. In most states you can recover up to 5k. Usually about $65 to file. Tell judge the whole story and ask for punitive $ also. I bet that gets his attention. Also u could file a complaint against him w the BBB and if he doesn't agree to refund they set it for a hearing. A bad BBB complaint or two can really hurt a business. Also spread the word among fellow riders - at bike nights etc. The word of mouth is usually the best or worst advertising a small business can depend on. You've got some power concerning this situation. Attack!!!
Sent from my LGL45C using Motorcycle.com Free App
I looked for a while to find someone that I thought could do a good tune, Harley had the dyno so I let them do the work. fair tune but I feel it could be much better. I don't think they put the time in the tune. So the next go round will be thunder max. I wish I would have done an auto tune in the first place.
After all that, you went back to him?
P
Guest
after the suggestion of 255 cams & 10.5-1 I wouldnt have been out of there (Im surprised the thing even started,does it have releases?)
I recently had cams and new exhaust done to my bike and added the PV at same time. I went to pick up bike and was told it ran great. On the way home it was great WOT but spit/miss/studder at normal throttle. I got the bike home and started looking at why. I checked the trouble codes and they reported the OC sensors were the problem. I ran the wires for the O2 sensors and found they had installed them backwards. Needless to say I wasn't happy. I changed the O2 sensors and it ran good. I got old parts back but some were missing. After taking inventory of what they sent back I sent them a bill for missing parts and an hour of my time. I got my parts but they wouldn't pay the hour labor. I won't be going back there again. This isn't all of the story but short version.
OP check the wiring for your O2 sensors and make sure they are reading the correct cylinder.
Discussion Starter #14
The bike started and ran good on the 255 cam but I didn't get any more performance out of the bike I even got a little less performance. The bike was already dyno tuned for the 103" big bore kit with the 255 cams when kit was installed in 2008 so just upgrading the heads (heads have ACR) and pistons worked with the old tune with a little adjustment of the AFR, I rode the bike for 1200 miles to break it in with the 255 cams while the new cams and throttle body and injectors were on order. After the 259E cams TB and injectors were installed the old tune was no good and that's when all the problems started because this guy doesn't have the right equipment or knowledge or both to tune the bike on the dyno with this build. I took the bike to the HD dealer Monday morning and I am getting it dyno tuned there because where I am at it is either the HD dealers or the guy that screwed up my bike when it come to dyno tunes.
Discussion Starter #15
After all that, you went back to him?[/QUOTE}
This guy has a 90 day warranty on his work so when the valve seals leaked I had no choice then to use the warranty. Like some mentioned before that I should have given him a chance to make it right and that is what I did with the valve seals. I still thought that this guy knew what he was doing and I know sometimes things happen so giving him the benefit of the doubt is why I had him install the new cam, TB and injectors. Right now it is the tune that is the problem and I don't know if I am going to have other problems until the bike is running.
P
Guest
with ex timing of the 255,they need compression releases for stock compression,releases or not,they should NEVER be set @ 10.5-1
Discussion Starter #17 (Edited)
The bike ran with the stage 3 upgrade with 255 cams with the SE head upgrade and the 10.5-1 pistons with the stage 2 tune. The bike did not run with the 259E cams with the 58mm TB and the 5.3 injectors. Changing the heads and pistons and using the old tune worked. The bike has ACR (automatic compression releases) and 259cams in it right now and it is a HD stage 4 build with all HD parts, this is the same build parts in the 2013 HD SE pro racing parts catalog on page # 51.
1 - 17 of 17 Posts
