1 - 4 of 4 Posts
Does anyone know what the torque spec's are for header bolts? Help is appreciated. Thanks!
This is for my 01 not sure on the newer so you may want to verify
Tighten the top nut of the front cylinder head
exhaust flange to 9-18 in-lbs (1-2 Nm).
lower nut to 120 in-lbs (14 Nm). Final tighten the
top nut to 120 in-lbs (14 Nm).
Repeat on the exhaust flange nuts of the
rear cylinder.
Eagle
Thanks Guys, much appreciated.
1 - 4 of 4 Posts
