Want to use Heat Demon's on my 2010 rg
Anyone have a tip or trick?
where did you pull the power source from?
They say you have to ream the id out to .875 the
ones my dealer have in stock are .870
How do you like them?
A
Guest
I have Heat demons on my '07,so I cant help with the fitment options...but they work great!! Good money spent..
I had some and could not install them on my 2010, the guy told me it would fit without reaming out the bar, but it did not work. If I remember it suggested that you run the power line under the tank to the battery. Simply put them on the wife's bike instead. You will need to ream out the bars to make it work;
I like these and am thinking of putting them on my 2010 this Fall...dealer said install would run $260--Wow! The demons are only $130. If anyone figures out how to install on 2010 FLTRX let me know.
Below is a PM I got from Mini SSS on HD Forums.
I'm using Khrome Werks +2 Sweepers. The machinist I used reamed out to 7/8 and because of the lenght of the grip area had to follow up with a 7/8 drill bit. He said he wouldn't recommend doing it again because the bar thinness and heat warped the bars a bit. I had to smooth out the interior of the bars with a hand drill, rod and sand paper. The exterior was no longer truly straight. Fixing it involved draw filling and shoe shine sanding it to get the new throttle grip to turn freely. It was a lot of PIA work. I hope you find a machinest to make the project easier for you. FYI, the air cushion type grips (ISO GRIPS) will not get as hot as ones that have full contact with the bar. There is a warning about this in the installation instructions. The TBW is what makes reaming out necessary. I believe the TBW slots at the end of the throttle end of the bars are what made the reaming difficult, because of grabbing of the edges of the slots with the drill and reamer edges.
It is a good day today. New Heat Demons , Iso Grips. +2 Sweepers, Elf 2125X amplifier. J&M 7.25 speakers work and the bike actually started since I started this project 3 weeks ago.
I know this is a lot of babling but I hope it helps with your future installation. BTW, The guy I called at the demon factory was very helpfull with a bad circuit board issue. He sent a new one within a couple of days.
If you have any more questions, feel free to ask. A lot of other guys on this forum were very helpful to me, so glad to pass it on. Cheers. John
Heat Demons
I have the Heat Demons on my '08. It is also throttle-by-wire and they fit just fine. I formerly had the H-D grip heaters on my previous bike (Road King). However, the Heat Demons are far and away superior.
Thanks for the info. Sounds like you're where I'm generally headed with mods, except for the handlebars. And stock bars may eliminate the problems like reaming, or maybe that's why HD wants to charge more than twice the cost of the demons to put them on! Hey, enjoy your bike!
