1 - 3 of 3 Posts
How long are 14" bars from the inside edge of the grip to the center hole? You can always extend the wires if those are the bars you desire.
I didn't measure the length of the wire when I installed the grips on both bikes, but I'm sure your local Harley dealer would open a box so you can measure them. On the Road Glide the power wire was long enough to run to the front of the fairing on the inside where I tapped into the wire going to the 12V accessory outlet. I don't remember how much extra length of wire there was to connect to the throttle side, but it didn't seem like much extra.
Just put 16" LA Choppers on a 2009 RG and the Harley heated grips were long enough. The twist grip side was plenty long, can't be sure if it was the original as Harley makes an extended version that may have been what I was dealing with and didn't realize. The left grip side includes an extention if needed. These were new grips too, not a previously installed version, so they came complete.
1 - 3 of 3 Posts
