1 - 3 of 3 Posts
I'd like to put HD cvo heated grips on my '18' RGU. The cvo grips are setup for internal wiring. Does anyone know if there is a power plug for the grips some where? Service manual shows one as black/violet wire. Can't find it behind the gauge cluster or under the fairing.
The 2017 Service Manual shows two plug ins for the handgrips which require the removal of the front fairing. There are several good YouTubes on the install. I've just started researching as I intend to add the to my 2017 RGU. Please post if you find anything.
Bill
Ok. I didn't completely pull the front fairing, just the black plastic piece above it. Guess I'll pull the entire fairing, not a big deal, had it off several times already. Thanks Bill.
1 - 3 of 3 Posts
