Got a new Mustang heated seat, states for a 2015 RGS that I will need an adapter harness, part #69200722. So I assume that will plug into the plug harness under the seat, and then where does the other end go or plug into :serious: Looked at a couple of online vids, but they are for older models that don't require the adapter.
Everything I've read makes it sound easy...I must be a real dumbazz :grin:
Pic of adapter
There is a free plug under the left side panel that it plugs into. If you want other connections, there is also another kit that includes the dash panel on/off switches. The routing of the plug to under the seat is a PITA, a little patience is needed.
Okay, one vid I saw mentioned that option, the lower gray plug pictured I believe.
So seat harness into adapter harness, then adapter harness into the side accessory
plug?
[/URL][/IMG]
