1 - 11 of 11 Posts
Pictures or it never happened …🤷‍♂️
Reactions: madmat and ToMang07
Been meaning to do this for yrs. Did you run into a catch can or just dripping?
Discussion Starter · #9 · (Edited)
I bought the elbows and tee's at Lowes. Item # 44219 , Mister Landscaper 4 pack. The fuel line I bought at O Rielly auto parts 1/4" ID.
Remove the caps on throttle body cover and drill to same outside diameter as fuel line from inside. Tape the face and drill slow and chrome doesn't peel. Use a good sharp drill bit.
Take a heat gun and warm up fuel line and it will press onto the existing breather bolts that hold cover/ support to the heads.
Feed the fuel line through the hole in cap. Slide cap until it fits in place, then cut fuel line to length desired. Fit 90 degree elbows.
add fuel line to elbows and route as desired , add the tee and route single line to bottom of frame.
I just have it open down by the floor board mount as of now. Might add a filter later date but do not think it will be necessary.
Been out for a few rides and isn't making a mess. wiped it once and that wasn't much.
1 - 11 of 11 Posts
