21 - 40 of 77 Posts
I spent many years riding in a suit and dress boots. One of the benefits of going to HD was I could stop ruining good dress boots.
Cut my teeth on dirt bikes as a kid, raced for many years into my thirties, then moved into jap and euro street bikes, and back-and-forth to Harleys in between. Never could get use to a heal shifter; never felt right not clicking up. It’s the first thing I take off.
Just bought a Road Glide yesterday, and the first part I bought was a heel shifter. I wear size 14 boots and went through three different sets of shift levers on my last bike trying to find my sweet spot.
So today I just put a standard length heel shifter on the new FLT. I find if I adjust the shift linkage “just so” I can adjust the heel shifter low enough that it doesn’t touch the board on the upshift but doesn’t require lifting my heel far to engage it, and the front shifter lever low enough that I don’t have to lift my big hoof much to downshift. I can still slide my boot under the front shift lever.
I think what a lot of folks don’t realize is that taller (and older) riders can’t always articulate their foot upwards for upshifts as easily with their knee at a more acute angle due to their height.
The human foot is not designed to lift in the manner that you use to up shift with the front lever. What else do you do that requires that motion? Those who don’t like the heel shifter just haven’t trained themselves to use it. Once you get it to muscle memory you’ll never go back. Plus you’ll hit neutral everytime because you’ll have the leverage to finesse it right in. Plus, saves you from scuffing the toes of your boots. :)
I think the heel shifter is the absolute best bang for the buck upgrade. For literally $50, bucks you can EASILY install this in 15 minutes. I think it increases the type of footware you can wear and not have to discomfort from shifts. Granted it does limit how far back you can move your foot on the floor boards, but I wear 10.5 shoes and never had an issue.
This right here is the reason I ordered a heel shifter after the second ride...
At 6'8", riding with my feet on the floorboards has my ankle already bent "upwards" a fair amount, so I can't easily rock my toe up to shift - end up having to lift my entire leg.
Lifting a heel is much easier on the ankles.
Trained????? I am untrainable, if you don't believe me just ask my wife!!!!🤣🤣
But you are right on one account it is easier to find neutral.
But neutral is over rated anyway !!!!!.........
OK maybe its not.......
Respectfully, this is particularly silly. :)
I have no issue with articulating my ankle, and I think it's more work to lift up your entire leg (however slightly) to use the heel shifter. Much easier just to blip my ankle with my heel resting on the board than to use the heel shifter.
Plus I firmly believe that the heel shifter contributes to shifter shaft/spline problems because without thinking about it much, the pressure riders use with the heel shifter is greater.
That's my opinion, and I'm stickin with it. :)
As I always say - I could be wrong tho.
I understand. Friend of mine just lost his shift shaft last week. He doesn’t have a heel shifter. Never lost one, myself.
Never had a bike with one. But then again, I only have had 2 bikes in my life. I think I’d want to try one before committing to buying one and installing it.
I like the heal shift lever and would not be without one on a bike with floorboards. I don't put any more pressure on the heel shifter than is necessary and never had a problem with bent shift forks because of horseing the upshift (it's called muscle memory) and simple maintenace checks ( which should be done, just like checking tire pressure) will assure a shift lever never falls off. They are easy to learn.....
I used a heel shifter for many years and 10's of thousands of miles. One day I decided I would rather have the room on the boards. Loved being able to move my foot around on the board in more positions and using just the toe shift and never went back. I've worked on motorcycles for quite a while and noticed that all the bikes I repaired with the dreaded shifter spline issues had the heel shifter. I have never seen the issue on a bike that the rider used toe shift only. It doesn't mean that just because one has a heel shifter that they will have the issue, it just means that it could increase the possibility because some aren't careful putting the weight of their leg on the heel shifter when shifting. I get people dispute this claim because they like using it. There are aftermarket solutions that help eleviate the spline issues from happening either way. Each person likes what they like so that's all it is. We tend to justify things based on our own opinion and not consider the possibility that there are other ways to look at it. Heel shifting just isn't that important to some whether it causes issues or not.
21 - 40 of 77 Posts
