1 - 2 of 2 Posts
I have a 2012 Road Glide Custom, I just ordered a HogPro 21" Titan and I plan to change out my lowers to Arlen Ness hotlegs, will the HD fork seal rebuild kit work with the hotlegs or do I need to purchase a different fork seal kit? I will be installing a progressive monotube suspension (1in drop) as well.
Any and all advice is greatly appreciated.
Semper Fi
Seals should be all you need.........the new legs should have their own drain screws and washers and the Mono tubes have all the internals you'll need. You can make your own seal driver out of PVC (look for a video by Gr8bigdude).... he did a leg swap and shows how he made his own seal driver)...OR Cycle gear has/had one on sale for like $35.00 recently......
Good luck!!
1 - 2 of 2 Posts
