1 - 4 of 4 Posts
So I have been pulling at the antenna plug and it slides in and out but seems to get hung before it comes out of the back of the radio....Is there a trick to removing? I don't want to force or break anything??
Never heard that before, is there a clamp on the cable or anything like that, how hard are you pulling?
Yeah, not normal- it should just slide right off with a good solid tug. I know this is obvious, but have you tried turning and pulling at the same time?
If you do end up buggering something, the guys at Iron Cross audio are great to work with and have fast the around times. Good luck.
Ian
Thanks for the input . . .I was a bit too tentative you with a solid pull it came out. The plug was actually longer than I expected. :cool::cool:
Sent the tach, speedo and radio face off to Marty for the blue light treatment. :eek:
1 - 4 of 4 Posts
