Hey guys... :-(
Very depressed. So I ride a 2015 Roadglide special, and I'm hoping some of you guys can help.
Last week I took the plunge and installed my new handlebars. Put it together, took it for a ride... Great. Rode it into work and then home, the next morning iv got nothing.... Turn the ignition on, headlight and running lights, and fuel pump would kick on, but nothing else. I pulled it all back apart, checked my connections and didn't find anything wrong. (Then I got the tumblers all outa wack in the ignition, built a tool, and realigned, bingo). Now today, iv got nothing at all. No headlight... no stereo.. nothing.
I'm overwhelmed. Checked the battery, all is well. Checked the main fuse, and fuse block, and I have no blown fuses.
Does any body have any ideas? Is there anymore fuses hidden else where? Any ideas would be greatly appreciated guys. Thank you :-(
Did everything work once you realigned the ignition ?
Hey guys... :-(
If the 15's have them, the first thing to do is check the maxi-fuse, and recheck all the other fuses with a multimeter. If those check good, then next step is to pull the ign. knob out again. I would bet it isn't really aligned, just moved around enough to get the knob dropped in. If any of this gets you back to things partially working, then it is time to have a real close look at the control plugs and make double sure you have every pin in the correct whole.
To the OP I've seen about 3 of your threads related to 14" Malos on a 2015 RGS, but all of the threads are incomplete. Have you found your issue? What did you do about cables when you got stuck in the middle of the install? I've got the same bars on order and I'm trying to get some information on what I'm facing, thanks
Check your DTC's? What codes if any do you have? DTC's will tell you a lot
