1 - 3 of 3 Posts
2001 FLTR
While installing the progressive monotube kit I have a problem
The cups that sit at the bottom of the factory air shocks in side the slider..
Do u reuse them with the montube install?
Seems damn tight sliding the shock up to install the top cap of the montube ( not the cap above the triple tree.)
I have the bike torn apart of course its saturday and the progrtessive tech line is closed!!!
Thanks guys
if you mean the ones at the bottom inside of the fork leg , yes you use them
1 - 3 of 3 Posts
