I need a crossover that’s not any wider than 4” and 7-8” long max, and no thicker than @1.5” give or take. Something with 12db-24db and we’re the mid contour cuts off at 3.5Khz, with a Hi contour like this pics shows and like one that can give a hi boost but not a must, but can go from 20hz-28Khz and yes I know it’s all air up there and sub woofer below 50hz just want to follow the woofer and tweeter specs as well as can handle @200rms, 400 Watts. Any input be helpful
Did you buy everything from Biketronics I see they sell that speaker as an upgrade, if so call Mike at BT. He is extremely helpful and will probably be able to help you out.
Try him anyway he is a good guy and you bought their amp. I am pretty sure they sell that speaker as an upgrade, he will probably have some ideas. I probably should have responded to your other post and not this one.
