1 - 2 of 2 Posts
Have a 2011 RG . Bike is raked with a 23" wheel ( hhi kit -cut neck) . Have problems with frt forks bottoming out . Can someone give advise on way I need to do ,such as maybe installing +2 fork tubes etc :confused:
If you lowered the front end and assembled the forks correctly, You can try heavier fork oil first, but i think you will need heavier springs, or pick up a set of progressive mono tubes.
1 - 2 of 2 Posts
