1 - 4 of 4 Posts
need some help here.got the forks changed out with monotubes and went to install them and neither one will go into the top triple tube.the left is about 1/4" forward and right same amount aft of top hole.what did I do wrong?
Our the pinch bolts loose enough. Rubber Mallot and some good wacky up could help too
After you check the pinch bolts, use a bit of emery cloth on the insides of the trees and windex the tubes.
Discussion Starter · #4 ·
got it,after dinner I went back out and looked at again,the bottom yoke can move independent of the top and I remember hitting the handle bars once when I walked by so I must of moved the triple tree when I did.anyway all's good,got one side in will finish up tomorrow.shiny willys chrome looks great.
1 - 4 of 4 Posts
