1 - 4 of 4 Posts
hi any help would be great have notice pinging when in 5th and 6th when I roll on the gas to pass on the freeway it goes away have also got 91 octane
in it ,power commander 5 filter woods 777 and a thunder header ,pulls
strong but that hesitation and ping noise is driving me nuts:confused:
You can retard the timing with the PCV. You'll have to go into the ignition tables to retard it. Dropping it 5 degrees in the problem area is where I would start.
I'm having the same problem, different cams exhaust and tuner
So got the fix from fuelmoto
they changed the map at the point of the ping a bit more fuel
problem solved 99% just a very slight ping ,much better :D
1 - 4 of 4 Posts
